G-Rad Posted April 15, 2012 Report Posted April 15, 2012 A buddy of mine was wanting to put 4 BC5500's in his ride and wanted to know about battery questions. He wanted to know how many D3100's would he need to decently run his 4 5500's and about 2kW of mids/high amps. He'll have 2 300a Alts installed as well. He was thinking 6 if possible just because there's space for it. What do you guys think? BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm
creed9 Posted April 16, 2012 Report Posted April 16, 2012 I'd have to say he's going to need more than 6 batts with only 600 amps of charging power.. I'd guess atleast 10 batts maybe someone else can put there 2 sense in. I'm only saying that because my friends got 6 hc2400s an got close to 900 amps of charging power on 4 sundown 4500s and I see how much drop he has
AA98hoe Posted April 16, 2012 Report Posted April 16, 2012 22k 2000plus amps of power dram on only 600amps of alt....at least a dozen batterys imo TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
TRTC360 Posted April 16, 2012 Report Posted April 16, 2012 Id say 16+ xp3000s with 750amp+ charging system, 22k+ is no joke. The xp3000s are more suited towards daily systems from what ive read but cannot be used as engine bay batteries. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
G-Rad Posted April 16, 2012 Author Report Posted April 16, 2012 Looks like he's gonna have to change up his game plan or something because he's not going to have THAT much space lol. ('97 Firebird) I'm just going on his specs. I wasn't sure, so this is why I figured I'd ask before he gets himself in a bind he can't get out of. BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm
TeamHT Posted April 16, 2012 Report Posted April 16, 2012 :facepalm: It's nice to dream, and not be afraid to dream big. But what the heck was he going to power with 22k watts of RMS power anyways in a Firebird. He doesn't even need that much power to get loud in something like that. Here's what he should do in my opinion: Wall off on two 18"s 4,000 watts RMS Curious on this dual 300 amp setup but if so a nice starter battery and two XP2000 in the back And he should be more than happy. Tell me...does this smell like chloroform to you?
fox_racin4 Posted April 16, 2012 Report Posted April 16, 2012 I'd have to say he's going to need more than 6 batts with only 600 amps of charging power.. I'd guess atleast 10 batts maybe someone else can put there 2 sense in. I'm only saying that because my friends got 6 hc2400s an got close to 900 amps of charging power on 4 sundown 4500s and I see how much drop he has Im the guy hes talking about I have 900a worth of alt, and 6 batts 10 runs of wire And 4 saz4500s I can drop to 12v on music if i want it to, i dont let it under 12.5v Even then its only for a few sec. Now on burps i see 10.x Which isnt good, im also running the amps at .35ea which is quite low... I plan on 6 more batts and a bit more alt 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
fox_racin4 Posted April 16, 2012 Report Posted April 16, 2012 Also, gains were set for vol. 52 and sub volume 0 I dont even turn it up higher then vol. 52 and sub volume -10 (pioneer deck) if that helps.. Not even close to full tilt 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
G-Rad Posted April 16, 2012 Author Report Posted April 16, 2012 I convinced him to reduce his power so he can breathe easier. and yes, he's doing a wall. 4 15's. BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm
