Enclosure Tuning below company recommendations?
crw092782
I have a pair of SA-12s and I am going to start construction in a week. The current box I have designed is tuned to roughly 30Hz right now. Sundown has said that they recommend 33Hz. What are the pros and cons to tuning below what is recommended? I am still new to the ported world. I have always built sealed enclosures. Thanks.
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
I will also say that I am running the subs on a HiFonics 2100.1D.
The box design looks like this.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Tuning low can help you reach lower. It can also help you control cone movement at lower frequencies. You may want to increase your enclosure volume to compensate, tho.
I model in WinISD to see my response curve. I'm running a RF 15" sub and I'm 7hz below their recommended port and about .66 cubes bigger. Sounds pretty good to me.
2007 Pacifica
Keep in mind their tuning is more than likely a best mix of SPL and freq response. Tuning a little lower may allow you to reach lower frequencies with reduced peak output, while tuning a little higher may give more output with reduced low freq response. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Thank you for your responses. I am going to just build this enclosure as is for right now. I guess I will just know when I am done if I like it or not.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
  • Who's Online   0 Members, 0 Anonymous, 1212 Guests (See full list)
