Cox Posted April 16, 2012 Report Posted April 16, 2012 Well here are my questions 1. Is there a way to tell what size box you can slide into a trunk (specifically an 09 camry se) because the inside of the trunk is plenty big for a box but the problem is just getting it in 2.I want to build a ported box for my two kicker cvr 12s. I built my first box and it was to big, and the second box i built for them works but......I'm sure they could sound much better So if anyone will help with a box design and help me figure out if it would fit, that would be great. Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Joe X Posted April 16, 2012 Report Posted April 16, 2012 Some poeple have attempted to make dummy cardboard boxes to see if it can go inside, once you get your dims rigth I could tell you if it's ok to build and eventually design it for you or help you to do it yourself. Quote
KOZ89 Posted April 16, 2012 Report Posted April 16, 2012 some people actually build boxes inside the trunk of the car as they go, basically meaning it's a one shot kind of thing, once build you can't take out, make any change of wiring unless you have the necessary space provided, in other words it's a caveman job build it, and when you done with it and time for a new build, you need to take it apart. Could also do some measurements see what you can work with, seen a decent size box inside a camry Quote build coming late April, early May build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/ 1997 Dodge Ram 1500 Slt Laramie Amplifier - AQ3500d.1 Sub - DC LVL 5 18" Highs - (2x) Selenium ST-350 Super Tweeters 8ohm Mids - Selenium 6" 200w midrange 6W4P (pair) Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch Wiring - XP Flex 25' Red, 25' Black Alternator - Mechman 270amp Battery - XS power D3100, 1- Yellow top front more to come...
Cox Posted April 16, 2012 Author Report Posted April 16, 2012 (edited) well i can take a picture of the trunk tomorrow and get the dimensions but the box i currently have in there is 36 wide x 17 deep x by 14 high Edited April 16, 2012 by jlccvr Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted April 16, 2012 Author Report Posted April 16, 2012 Enclosure Specifications: Fb = 37,503 Hz Vb = 4,5 ft^3 Subwoofer Mounting = Flush Mounted External Height = 14 in External Width = 33 in External Depth = 25 in Port Width = 4 1/2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 27 3/4 x 12 1/2 Front Internal = 27 x 12 1/2 Back = 33 x 12 1/2 Left & Right Sides: Side 1 = 23 1/2 x 12 1/2 Side 2 = 22 3/4 x 12 1/2 Top & Bottom = 33 x 25 L Port Internal Assembly Parts: Front to Back = 14 3/4 x 12 1/2 Assembly sample (generic dimensions): Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted April 16, 2012 Author Report Posted April 16, 2012 that is what i want to build Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Joe X Posted April 16, 2012 Report Posted April 16, 2012 (edited) that is what i want to build I did that one a while back but if I remember right the OP was going to build inside the trunk, be aware that this will likely be the case for you. Edited April 16, 2012 by Joe X Quote
Cox Posted April 16, 2012 Author Report Posted April 16, 2012 well i cant really do that considering thats where my spare tire is soo.....do you have any other designs that could fit 2 cvr 12s without having to be built inside the trunk Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Joe X Posted April 16, 2012 Report Posted April 16, 2012 well i cant really do that considering thats where my spare tire is soo.....do you have any other designs that could fit 2 cvr 12s without having to be built inside the trunk I can custmize one for you, just make sure what you can fit, do a cardboard dummy or maybe get the info from another member's build, should be the same year if possible. Quote
Cox Posted April 16, 2012 Author Report Posted April 16, 2012 well now that i think about it, do you think it would maybe just be a better idea to do a sealed box since they take less space, or do you think you can come up with a small enough ported design? Quote Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
