I know most of you probably think a sealed box for this sub is stupid but I wanna try it and see what result I get for a SQ setup. Just trying to figure out what I should do as far as internal volume. RE recommends 2.1 cu ft but someone the other day suggested 3 cu ft. At what point will a sealed box be too big where I could risk damaging the sub? Also when tuning an amp for a sealed box where do you set LPF and subsonic?
i had a L port box @ 3.92CuFt after displacement, and it sounded absolutely fantastic.
so i mean i know it doesn't totally pertain to having it in a sealed enclosure, but take it for what its worth.
if i remember correctly, isn't there a formula or spread sheet for recommendations to convert from ported to sealed internal volumes?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
What did you have it tuned to? And im not sure about there being a chart for converting but RE has specs for both sealed and ported im just wondering when a sealed box becomes too big and when it can damage a sub.
Posted (edited)
mine was tuned to 32.9Hz
absolutely killed on the lows
not totally sure on when it becomes too big,
i never much dipped into sealed boxes
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
I was considering making another one tuned a little lower also. I am currently around 35 hz, which doesn't sound bad. I just re tuned with the DD-1 and it was sounding real good! But I either wanna go sealed or aero ported on my next box. Just not familiar with either
Any other help for sealed box's?
Block th port of your current box with some MDF to get an idea of what sealed will deliver.
  • Who's Online   0 Members, 0 Anonymous, 670 Guests (See full list)
