RE XXX 15 sealed box question
I know most of you probably think a sealed box for this sub is stupid but I wanna try it and see what result I get for a SQ setup. Just trying to figure out what I should do as far as internal volume. RE recommends 2.1 cu ft but someone the other day suggested 3 cu ft. At what point will a sealed box be too big where I could risk damaging the sub? Also when tuning an amp for a sealed box where do you set LPF and subsonic?
i had a L port box @ 3.92CuFt after displacement, and it sounded absolutely fantastic.
so i mean i know it doesn't totally pertain to having it in a sealed enclosure, but take it for what its worth.
if i remember correctly, isn't there a formula or spread sheet for recommendations to convert from ported to sealed internal volumes?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
What did you have it tuned to? And im not sure about there being a chart for converting but RE has specs for both sealed and ported im just wondering when a sealed box becomes too big and when it can damage a sub.
mine was tuned to 32.9Hz
absolutely killed on the lows
not totally sure on when it becomes too big,
i never much dipped into sealed boxes
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
I was considering making another one tuned a little lower also. I am currently around 35 hz, which doesn't sound bad. I just re tuned with the DD-1 and it was sounding real good! But I either wanna go sealed or aero ported on my next box. Just not familiar with either
  • Who's Online   1 Member, 0 Anonymous, 1337 Guests (See full list)
