Just recently got my first car and have installed my old set of 15's in it, but I sold that and am ordering new stuff. I have two Power Acoustik 15" MOFO 152x's on the way along with a SoundStorm SSL 4000 watt monoblock amp. Using a 0 guage wiring kit. This is going in the trunk of a 2000 Nissan Altima SE, and my trunk dimensions are 32" wide, 17" high, and 25"(Give or take) deep . And I want to go ported and have a tuning of around 33hz. The subs would be firing towards the license plate and the port I'm thinking should be at the top back.
But what I need to figure out is the port dimensions and whatnot needed to get 33hz. Sorry I'm a little noobish with this, the help is appreciated.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Posted (edited)
Um, I dont' want to bring the bad news...but that's not really enough space for those subs, since they call for 3 cubs each...and just by looking at your dimensions...you're stuck at 6.43cubs without adding the displacement nor the port area. Unless you'll be overpowering them.
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Well what do you suggest? Go sealed? Or would a slightly smaller-than-it-should-be ported box be better? The pair of subs has a 6000 watt total max, and 3400 watt total RMS. Given that my amp is 4000 and will be at 2-ohms they will be underpowered.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
He could make it work. The port would have to be all external though
How do you suggest I do that? The port can't fit on the sides of the box, only along the top. And I can get a few more inches of height if need be.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Posted (edited)
Could you post some pictures of what you are working with?
Sure thing, I will post pictures in a couple hours when I get home.
Edited by Raptorman
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Posted (edited)
Sorry for the quality of these pictures, I don't have a good camera. But these will suffice.
Trunk entrance height. Can't see the tape measure well but it's 17"
http://s1055.photobu...4-16_153023.jpg
Trunk height - 17"
http://s1055.photobu...4-16_152941.jpg
Trunk width - 38" but the trunk entrance will only let me put in 32"
http://s1055.photobu...4-16_152919.jpg
Entire Trunk
http://s1055.photobu...4-16_152803.jpg
So it can't be 38" wide unless I can like build a box in halves and slide each half in and then glue it together and whatnot once it's in and let it sit. If there's even a good way to do that, hahah!
Edited by Raptorman
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Sealed. Can't do ported...unless it's a single sub....you just don't have the space needed.
Alright thanks dude.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
