DC Sound Lab
OK so i bought 2 Dc lvl 2 12's and i want to know if the box for my old subs would be ok or if i should build a different one the one i have now is 5.38cuft with the sub displacement accounted for in torres box calc and the site says 1.25 each ported but i think i will probably be under powering since Dc subs are under rated and the amp i have is a vibe black box bass 5 rated at 1500rms at 2ohm and it is a mono block so any help would be appreciated thank you
Edited by justin_garrett
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
box is a little big.. should be fine tho for awhile till you get another box made etc.. turn the amp down and stay within mechanical limits of the woofers
bigger box means less power
smaller box more power
ok how does this look for them i took the cubes down to 2.63 so there getting about 1.31 each but the port is not going to be 8in long there going to be 20 but will come out of the box but 8in will be in the box newbox.jpg
2000 Eclipse
now that box is way too small and the tuning is fuckin high.
the ports are actually going to be 20in long for a tuning of 33hz but only 8in of the port is going to be in the box i did it like that so i could see how much cubes the subs where going to actually see here is the sketch up of it box1.jpg so about how many cubes do you recommend they will be ran off a 1500rms mono block amp set with a dd-1
2000 Eclipse
4 cubes total with a 6" aero...
This is 3.5 cubes with 1500 watts.
http://www.youtube.c...ns?feature=mhee
lol because its the box you built, its the box everyone should build.
well the ports are going to be 2 4in aero's as that's what my box already has i just need to figure out what cubes to go with as i made my box to where i can slide the baffle in and out of the box so i can change the amount of cubes the sub's are seeing
2000 Eclipse
just to check, how do you seal and attach the baffle once moved?
  • Who's Online   1 Member, 0 Anonymous, 650 Guests (See full list)
