caspers bass Posted April 16, 2012 Report Posted April 16, 2012 so i just got rid of my sdc 2.5 15 and im going to get a hdc 18 and i was wondering what the box size should be? i was thinkin 7 cube ft and tuned to like 37 hz and also should i get the d1 or d2 im only gettin one sub so i was thinkin the d2 and just wire down. im running a ap1500.d for a few weeks till i can get an aq2200. basically thats about it.
pa-pa-platypus Posted April 16, 2012 Report Posted April 16, 2012 anywhere between 6-7 cubes you should be ok...id stick closer to 6 cubes on the 2200 tho..these subs like big boxes but are throwing a decent amount of power at it tho This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
wmrcs Posted April 19, 2012 Report Posted April 19, 2012 My box is about 7 cubes after displacement and it could take another 700ish before I would make the box smaller. I'm only running ~ <1200 though E34 540iT/6
