So I created a .752^3in. box for a Sundown SA-8 v2. The dimensions are:
Length: 18"
Width: 10.5"
Height: 9"
Port: Width: .75"
Height: 7.5"
Length: 17.5"
Here are some pictures:
de2572007d8451973cf9d7420df5b1fc.png?1334632312
3404f5f062dc6bb5759eda343dafe9cf.png?1334632811
After building the box, I discovered that it creates port noise around any frequency below 44Hz (Which I guess is because I didn't keep the port's width and height to a ratio of 1:8). I was wondering if anyone could possibly help me with this situation. I've looked into a round port, but the calculator said I would need at least a round port with a diameter being 4" and a length of 38", which is too long for me.. So if anyone wouldn't mind helping, I'd really appreciate the help :)
Thanks
you need more port area. round square or whatever, larger the box = more surface area you need on the port = a longer port = a larger box.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Ports get longer as the net volume gets shorter, Your gross volume is 0.7 not the net as it should be, I designed this for you, I think the easiest is repeat the box in this case:
Enclosure Specifications:
Fb = 36.055 Hz
Vb = 0.7 ft^3
External Height = 10 in
External Width = 25 in
External Depth = 10.5 in
Port Width = 1 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 25 x 10
Left & Right Sides = 9 x 8 1/2
Top & Bottom = 25 x 9
L Port Internal Assembly Parts:
Front to Back = 7 3/4 x 8 1/2
Extension = 17 3/4 x 8 1/2
The box assembles just like yours:
Build it or just use it as a reference.
Thanks. But I've looked more into it, and I think I'm going to keep the box. I've downloaded WinISD and input the SA-8 v2's parameters then messed with the port tool. This is what it gave me (with circular ports):
391cda1e2fc6a53c01ef0c9134767cb7.png?1334696432
Which gives me a peak at ~40Hz @ 5.7dB with a 36Hz tuning, but can reach 32Hz @ 0dB. Plus the 'Vent Mach' is (from what I've read) supposed to be as close or under 5%, and .04 is 4%, so I guess I'm good there. My original port gave me a Vent Mach of .1 or 10%, which I guess is really terrible. I guess I'll take out the port and seal it, then get some 2" PVC piping and cut it to 15.5" and have about 6" of it inside the box, which should look a little something like this:
cf3ffa290b15da90ff99458470f63771.png?1334697073
4c54e754d42d3bdb82ed0b7a5d5777f4.png?1334697119
Posted (edited)
Technically, probably so, you have nearly 7 square inches of port per cube (your net volume is also a bit high with this).. I wouldn't keep a box that looks like a science experiment though .Probably you have enough wood left to redo it at no cost... obviously that's only me.
Edited by Joe X
  • Who's Online   0 Members, 0 Anonymous, 7186 Guests (See full list)
