i want to do a hair trick i think it's awesome i got a 2000W RE SX 18 1000W RMS i have a 2000W RE amp rated 1200W RMS 10 fraud cap i built a box for it out of mdt 3/4 plywood spose to be 8.2207 cubic ft 36 wide 32 deep and 15 high i put a port in it 8 by 9 1/2 and 10 1/2 inches long sounds good and i believe its tuned to 38 htzs do i need to change the tuning? or something?
OP, DJ crush was being sarcastic. To do a hair trick you need low tuning, good song, alotta power .
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
he was making a joke, as in it wont happen.
Box seems big if thats net volume, id run 2 of those 18s in there. Ran my 15s in 1.5 cubes less than recommended per sub. Did alright too
What vehicle? A mini hairtrick is possible... got to move a lot of air..depends on car box subs power etc
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 3047 Guests (See full list)
