Demensions on a ported box help please!!!
I am going to be installing a system in my 2008 Lincoln mkz, trunk is fairly large...
I need someone to help me out so I can just cut the wood and screw it together for perfect a ported box frat will fit the specs
2 Rockford T0's 12's
You need to measure out the max dimensions of your trunk and see what will fit...
And for specs...look on the rockford site..
i will let you know...if you want help you will need to give the max dimensions you have to work with...width, height and depth of the cargo area...
you might want to let people know what kind of power your running, music you listen to, or what area your wanting the port tuned to...otherwise your not going to get anywhere
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Sorry I'm a little new to this, I will be running a hifonics Brutus 1700 for now... And tuning wise honestly i just want it to get loud and hit most of the notes... I mainly listen to rap music and I don't have the exact dimensions but I guarantee I can fit just about any box necessary to meet the requirements of 2 t0's it's a big trunk lol
i understand that..its similar to the Ford Edge which I have driven many times...the trunk is a nice size..but people will want the measurements to help you...width and depth for sure...some people dont care if the box is taller than the backseats or not..but things like that determine how much space your box will take up and how to tune it also...
if you listen to mostly rap i would suggest tuning in the mid to low 30s...
here are specs for your subs
http://www.rockfordfosgate.com/products/product_details.aspx?itemid=120431
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Idk if this would help any but . http://www.the12volt.com/caraudio/boxcalcs.asp or
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
ok...here is some numbers for you to work with..
18h x 34w x 26d external measurements
16.5h x 4w x 28d port measurements (will have a bend in the port)
gives you tuning of 32hz
4.96 cubic feet after all displacements for subs/port/bracing
13.31 inches of port per foot
66 cubic inches of port area
.6 sub displacement
1 extra baffle
.25 bracing
.75 thickness of box material (mdf)
download torres calculator on here and if you input those numbers you should get your cut sheet
now that is just a rough box...there are people who can design you way better..but this is just so you get an idea of what you need or might want..
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator/
Edited by stroupe79
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Ok so here is another suggestion:
Enclosure Specifications:
Fb = 33 Hz
Vb = 4.5 ft^3
External Height = 16 in
External Width = 34 in
External Depth = 24.75 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 16
Left & Right Sides = 22 1/2 x 14 1/2
Top & Bottom = 34 x 22 1/2
L Port Internal Assembly Parts:
Front to Back = 18 1/4 x 14 1/2
Extension = 2 x 14 1/2
Let me know any questions.
  • Who's Online   1 Member, 0 Anonymous, 1240 Guests (See full list)
