Guest MegaloManiac
then why do they make a dual 2 ohm woofer, if you cant run them at 2 ohm?!?! seems pointless..
its DUAL 2 so you can wire it @ 4 or 1 ohm... you should have bought a dual 4(2 or 8ohm option) or dual 1(.5 or 2 ohm) if you wanted 2 ohm. or if you amp is capable of 2ohm x2 then wire each coil to a channel...
makes perfect sense...
