Sundown Box Designs (Google SketchUp)
Got bored, so I did a couple of designs for dual sundown audio setups.
Down below consists of the Nightshade 10s and 12s as well as SA-12.
Going to be adding a few more soon
Subwoofer displacement, baffle displacement have been added
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
For the SA-12's, gross volume being 4.61 cubes.. What would it be after sub displacement??
2 - Sundown Audio SA-12 D4 (Box tuned to 34 hrz)
1 - RF t1500.1bdcp
1 - RF t400.4
2 - JL Audio C5 5 1/4 in front doors
2 - JL Audio C5 570 in rear deck
2 - JL Audio ZR100 in front pillars
1 - Kenwood ExCelon HU
3.07. I cut off the list of the displacement and such. Recommendation is 3ft^3 volume for two SA-12s so I'm a little over the recommendation.
That's actually on the small side, specs for SA 12s are 1.75-2.25, sometimes even 3.5 is a little small as they like larger boxes up to about 4-4.5 cubes. Little much on the port area too, generally around 12 is best
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Hmm I looked off the Sundown Website...I could've swore it was 1.5-2ft^3 per sub..
I based it off minimum recommendations...for more power to be ran to them
Still gonna be closer to the small side, never had any luck with My smaller boxes on even more power, my 2 best were 4 cubes and 4.5 cubes, both on my 3500 in daily applications.
Only recommended smaller applications for SPL, which you would also be needing a higher tuning (40+)
Team Sundown Audio
Ah okay, I'll update it later, Thank you for clearing that up. I am basing my info off of car trunk dimension...that's why all of them are mostly 34-36" wide.
Try a single 6" aero for SA12s of your limited on space with 8-10" of port for the aero. The aero box I did was 4.5@35hz with a single 6 and it destroyed lows
Team Sundown Audio
Okay will do. Thanks. Didn't even think of that, I am a slot port fan..so I normally lean that way.
