Guest Posted April 20, 2012 Report Share Posted April 20, 2012 (edited) That's right the only good amp Ask them how long it been working for and test it output now There are heaps better products out that will produce better sq and last longel for a small amount more LOL http://forum.realmof...html#post537229 11.3v, 1.03 ohms, 2850w. 12.3v, 3732w. 15.7v, 1.4 ohm reactive, 4640w. now shut the hell up. Edited April 20, 2012 by Kranny Quote Link to comment Share on other sites More sharing options...
soundsystemaniac Posted April 20, 2012 Author Report Share Posted April 20, 2012 (edited) regardless, it's not as impossible as it may seem. it's doable. So your saying its doable, but that would require me to build it in the trunk right? I can get some more precise measurements soon Edit: also, im limited in port sq inches to 100 because the ski hole pass is 8x17. and thats before wood thickness also. what kind 15" of subs do you think would do well in a smaller bandpass box Edited April 20, 2012 by soundsystemaniac Quote Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228 Link to comment Share on other sites More sharing options...
412 CVX Posted April 20, 2012 Report Share Posted April 20, 2012 sundown subs usually work well in smaller enclosures. i haven't taken much of a look at the airspace you have, so i'm not sure if it's possible in your situation. i'm just saying it's been done lol. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
john253a Posted April 20, 2012 Report Share Posted April 20, 2012 (edited) The only way I can see 2 15 fitting is port rear into cab and free the front in rest of trunk It will take a lot of calculations to correctly work out volume and a sum of good sound deading A local shop near me done 3 JL15"s this way in a WRX Edit It's not the best way to do it but may work for you Edited April 20, 2012 by john253a Quote Link to comment Share on other sites More sharing options...
