jazza02 Posted April 21, 2012 Report Posted April 21, 2012 Well i picked up a Schneider SPA7000x since i traded my last one. This is works fine for a little then, bamm straight into protection mode. leave it go unhook everything. hook it back up. works again. Then the same problem again.. I know it;s not my wiring because at the time i had the other amp at the time and it was working. Iv;e taken it to my local car audio shop and they it's somthing the power on board ? I have no clue. But it's been in there since christmas and its starting to piss me off. cause they don't know who to contact about it. ( australia shop) Does anyone know if this could be the problem ? like it powers up and thumps the sub hard as then stops lol. CURRENT SET UP Factory HeadunitGladen dual splits Audio helon 4ch amp Audio Helon 9kwrms monoBlock 2 15" Custom built Pap subs rated at 3kwrms each
WolfieGeez Posted April 30, 2012 Report Posted April 30, 2012 Well i picked up a Schneider SPA7000x since i traded my last one. This is works fine for a little then, bamm straight into protection mode. leave it go unhook everything. hook it back up. works again. Then the same problem again.. I know it;s not my wiring because at the time i had the other amp at the time and it was working. Iv;e taken it to my local car audio shop and they it's somthing the power on board ? I have no clue. But it's been in there since christmas and its starting to piss me off. cause they don't know who to contact about it. ( australia shop) Does anyone know if this could be the problem ? like it powers up and thumps the sub hard as then stops lol. Does this happen when the car is just sitting there? Or when its moving and rocking around? Because it could be a loose connection, but you said you checked wiring. Have you taken a look inside the amp for any fried mosfets/components? THE TC SYSTEM: >2003 Honda Civic DX coupe >1 TC Sounds TC-3000 1.4QVC >3cu ft 6" aeroport tuned to 30hz port⊂ forward facing sealed from trunk >US amps Xterminator XT-2000D (soon to go) >Pioneer DEH3000ib >Soundstream BX-20Z Digital Bass Processor >Knukonceptz 1/0 gauge wire >Knukonceptz 1/0 gauge wire big 3
Noel989 Posted April 30, 2012 Report Posted April 30, 2012 That same thing happen to me it would play then stop then some weeks later it was playing and then boom it fried. If you can test it in a different car to see what kind of results you get Build Log - http://www.stevemead...-cruiser-el-pt/
