Look what I just got off Craigslist
hell yeah its a great deal. im hoping it came with it and he isn't planning on using it.
Whats wrong with using an isolator? I've never used one before so any info on why not would be good.
isolators cut off your battery from getting a charge from the alt. essentially making your amp see like 11v while playing music. once your battery drains enough, the isolator will switch power over so the alt will charge it. which is fucking HORRIBLE for an alt. it puts so much stress on the alt and causes tons of wear.
isolators are used mainly for show cars that play music with the car off, so that they dont have to worry about their starting battery dying once they're done playing music.
No shit? I thought an isolator only killed the connection between the 2 batts when the power was off?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
^ that.
edit: what Kranny said.
and no, it permanently separates the 2 circuits. permanently as long as the isolator is installed.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
unless you plan on playing your system with the car off. i wouldn't use it. when the car is off, it seperates the batteries by an internal relay and doesn't let one discharge the other. hence, isolator. when the car is on, it allows current to flow between both batteries with no problem
2000 FORD EXPEDITION EDDIE BAUER
current system
(1) Pioneer DEH P8300UB
(2) Massive audio nx4 mids and highs amps
(2) Soundstream sst-654N
(2) Soundstream sm-654N
(4) Soundstream sme-574P
(4) Massive audio ct1-a aluminum dome tweeters
(4) soundstream sst-05 bullet tweeters
(2) Soundstream x3.182 subs
(1) Cactus Sounds k5
XS power batts
Mechman alt
no its permanent like skippy said. it will ONLY let your alt charge the rear battery once the voltage drops below a certain point. i dont know what it is exactly, but its well well below 12 volts
it doesn't ever allow current to flow between the 2 batteries. car on or car off.
F150:
Stock :(
Processor: DSR1
What do you guys suggest? It being an under the hood batt or an addition to my stock wet cell batt? If an additional battery, how should I wire it?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
if you can replace the stock batt with it, then great. if not, just put it in your trunk and run a piece of fused 0 gauge from the front batt to the rear. ground rear batt to frame/strut tower, with paint sanded off. hook up amps to rear batt.
That's what I was planning. But the 2 batteries won't mess with each other being directly connected?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
i need to find a deal like that for 4 of those......great find u lucky prick...lol
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
  • Who's Online   1 Member, 0 Anonymous, 917 Guests (See full list)
