BBP6 vs Torres' Question: Port lengths are different, New box build.
1 Sock
2 12" BL loaded on 2500 watts going into a 2003 f150
will be using 6" aero ports,
Subs down ports out 1 side.
The same specs in Torres' do not match the ones in BBP6
The same tuning is showing different port lengths.
Small boxes below are BBP6, everything is the same.
Is Torres' more reliable than BBP6?
you dont have a calculation for the flare ends on torres calculator. also you have torres saying the port bends
The ports are going on the side, the calculator does not account for that.
Could you tell me how to calculate the flares?
Thanks for the help.
do you have the flares? if you do the paper that comes with them tells you how to calculate them.
in reality the difference in those 2 boxes will be inaudible anyhow.
Flares are on the Fed Ex truck coming Thursday. Ill check out the paperwork.
Thanks for the info.
  • Who's Online   2 Members, 0 Anonymous, 744 Guests (See full list)
