1994 Volvo 940 Project (WITH SOME ROCKFORD FOSGATE AND DC AUDIO!)
Time for MOR updates! Last night I got all my wire to the trunk, back seat put together, and I took apart my factory dash speakers so I could mount the front tweeters inside of them.
Everything going in to the trunk. Drilled some holes that were already there a little bit bigger to get the wire as close as I could to the floor.
Looking good, except here. GET A GROMMET ON THAT POWER WIRE! That sheet metal will cut through that jacket and things will be alllllll bad! A $.25 piece of circle rubber (grommet) will stop thousands of dollars of destruction!
Otherwise it's looking good! Tuned in!
Actually after taking this picture i wrapped the wire in tons of electrical tape to protect it but i would like to eventually get a grommet on that.
  • 2 months later...
I didnt take many pics of the driving light install but here is what I have.
I mounted the two relays for each set of lights on this brace using bolts that were already there
I ran the wires with all the factory wires. After I took this pic I hid them behind the factory stuff
The travel through this grommet and come out under the dashboard. There the fog-light relay gets attached to the factory fog-light switch and the Driving light relay gets hooked up to the high-beam switch with a kill switch in the middle so I don't always have to have them on with my highs.
Fog-lights got mounted into the metal bumper from the bottom and the driving lights got mounted to the plastic on ether side of the grill.
Here she is all done!
Its getting close to the end of the season here in N.H. so not much more will be happening till spring. Finally then this car will get a little closer to the ground along with other suspension upgrades.
I'm still loving what you're doing to the Volvo in general, and it looks like you're taking great care of it as well.
Props on your photography as well
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
