RF4LIFE Posted April 25, 2012 Report Posted April 25, 2012 I have a 2004 Ford Explorer and I putting a large system in it. I have the stock 130Amp Alt. and the stock batt. I have two amps and combined they are at least 2400w RMS and will possably be as high 4100w RMS. I did the Big 3 upgrade and I'm wondering if I will need a bigger Alt. and if so how big should I get? Also how many extra batterys should I get and what size amp or amphour should they be? Size Isant unlimited so the smaller the better so if I can use one larger vs two smaller than let me know. Thanks Quote
TRON Posted April 25, 2012 Report Posted April 25, 2012 (edited) I'm no professional but I understand electricity enough to tell you that you definitely need a HO alt/battery The total wattage that your vehicle can produce is found by multiplying the amps by the voltage. 140amps x 14.2 (typical charge) = 1988 watts available. Consider that your vehicle uses some of that power...lets say 60 amps? (60x14.2= 852watts) that leaves you with 1136 watts left over for any aftermarket electronics. Also consider that NO amplifier is %100 efficient... maybe %80 and that's really good. If you want to run a total of 4100watts ( 4100/14.2=288amps) You need a minimum of 288 amps surplus. Check out Mechman or Singer alternators, you'll probably want something big like 350 amps or dual alts. And make sure you get a battery or two because the battery acts like a filter to smooth out the current created from the alt as is converts AC to DC So see what XS power has for your application. !Send emails to these people, they'll hook you up with the right stuff! *remember* - Wattage is the transfer of electricity...not "power" or whatever. Your amplifiers say they can make 4100 watts ONLY if that amount is available. If you don't have enough current to feed your amplifiers they will try to draw more power, resulting in a voltage drop which will cause excessive heating and probably do bad things to you battery or alt. - fixed my horrible spelling - Edited April 25, 2012 by TRON Quote Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
RF4LIFE Posted April 25, 2012 Author Report Posted April 25, 2012 So I should be looking at my Amps RMS or Peak Watts when trying to dice an Alt.? 4100w RMS / 14.2v = 288.7A 288.7A + 60A (for the electrical systems) = 348.7A 8200w Peak / 14.2v= 577.5A 577.5A + 60A (for the electrical systems) = 637.5A So should I look for a 350A Alt. or like two 325A Alt's? And what size batteries should I get for the back? Quote
Trey_Dog650 Posted April 25, 2012 Report Posted April 25, 2012 Always look at rms. and I think you'd be fine with a 350 amp alt plus an upgraded stock battery and 2 more in the back for a total of three. Quote 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
RF4LIFE Posted April 25, 2012 Author Report Posted April 25, 2012 How big should they be? CA? CCA? Do Thoes matter? Quote
Zapanater Posted April 25, 2012 Report Posted April 25, 2012 That refers to the cranking amps, which is a useful measurement when you need a large discharge over a short time, such as cranking over an engine, but not terribly useful for the continous drain of a high power system. Generally speaking though, the more cranking maps, the better the battery. Otherwise, look at the "ah" rating. THis is ampere hours, and let's you know how much reserve it has. A good battery like an xs power d3100 has 110ah. It doesn't even tell you the cca or ca on their site. Id think one of these would eb enough, or two conventional lead acid batteries, provided you have an upgraded alternator. Check out maniac motors for an HO alternator if you're on a budget. Quote 2015 Subaru Outback. That is all, I refuse to touch it.
RF4LIFE Posted April 26, 2012 Author Report Posted April 26, 2012 Well should I just get like two Yellow Top batteries? As big as I can fit? Quote
CrownVic Posted April 26, 2012 Report Posted April 26, 2012 just get the biggest sealed batts you can fit/afford if you plan on playing the system much with the car off. Quote
TRON Posted April 26, 2012 Report Posted April 26, 2012 Well if you're talking about over 8000 watts peaking then you'll definitely want to run dual 300+ alts and two or three batteries. Id say for batteries... XS Power's D3100 or XP3000. These batteries have the best Ah (amp hours) and maximum amp ratings. Terribly pricy but that's the cost of big power. I'm betting that you can get two 350 amp alts and the necessary hardware from Mechman. You'd have to find out if you can run two alts under your hood becasue typically, when you have multiple alternators, you leave the stock one in and just add extras, then you know that your aftermarket alts are only supplying power to your amplifiers. Quote Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
skittlesRgood Posted April 26, 2012 Report Posted April 26, 2012 So I should be looking at my Amps RMS or Peak Watts when trying to dice an Alt.? 4100w RMS / 14.2v = 288.7A 288.7A + 60A (for the electrical systems) = 348.7A 8200w Peak / 14.2v= 577.5A 577.5A + 60A (for the electrical systems) = 637.5A So should I look for a 350A Alt. or like two 325A Alt's? And what size batteries should I get for the back? be worried. the info in this thread sucks so far. your math is off because you didnt factor efficiency. you need more like 470amps. dont ever ever ever ever ever ever ever, ever look at peak or max power ratings. they are useless. rms only!!! so a 250amp alt with a higher idle output than a 300amper, with two xs power 2400s plus a starting battery and you will be covered. Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
