Dc audio level5 reverse mount?
New to stereo install got 1 level5 12 arc audio ks 1000.1 mono block i wanted to run it magnet up to finish off the hydraulics and show off the magnet i was not sure if it was capible also i have rainbow 6.5 set and arc audio ks 300.2 for the front anyfeed back would be great this is my first system i want to be sure its right
I don't see why not. Just be careful to make sure the surround doesn't rub on the cutout at all. I might use t nuts or bolts to mount the sub to complete the look and also because it'll be top heavy and could pull out screws. Run the wires clean obvi and post pictures fool :P
Also welcome to the forum :)
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Meh screws will work fine theres slim chance of pulling em out unless you like to go drifting but still..
Setup:
Xs D3400/ Xs XP3000
I have a feeling if you have a lvl 5 inverted and you have hydraulics that you could damage it. That magnet is heavy and bouncing around like that I'd be worried of it bending the basket or something.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
I somehow missed the hydraulic part.. yea. That does sound concerning but I have no clue as to whether or not the basket can withstand that kinda forces
Setup:
Xs D3400/ Xs XP3000
Thanks for the help i think your right about the weight i dont want to damage it also any sugestions on wiring it the manual for the amp has several different ways of hooking up the two voice coils to the one amp chanel what would you guys do for a daily street system thankS
Mabey that was the wrong term im talking about the imputs for the speaker wire on the sub there are two the book for my amp shows them hook up in different ways one would be poss on one side neg on the other one of they other ways is poss and neg on both termanals jumped together and then out to the amp arc audios manual was pretty vauge i just want to be sure it is wired the best way for the best sound im a fabricator by trade this is my first system if i was "z"ing a frame or building a hydraulic setup i would feel better but this is out of my relm of experiance thank for the help
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1074 Guests (See full list)
