is ti possible to get floor noise from under powering the tweeters? i changed from 25watts x2 to a 50 x2 an seem to get rid of it do you think its just in the amp, might be a reason for me to get a couple zapcos
is this a hard question ? or is it alot of people dont know what floor noise is? im not talking about floor noise from under your feet its only in the tweets so im trying to figure it out
higher freq speakers pick up ground noise alot easier.i noticed in your sig,you don't have the big 3 done yet.
try that and see if that helps.
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
also,could be bad rca's on that amp for those speakers.
do you have the rca's running along by the power wires?
eclipse cd2000
rf p4004
well i used the same rcas when i changed the amps from 25watts to 50 which almost got rid of the noise so i figured the amp was problem i plan on big 3 real soon so ill see then but i think im just gonna switch amps an get a new one for the rear it seamed cleaner also when i switched it over when you do the big 3 do you leave origanal wires an add 0/1 gauge to it or just use 1/0 gauge ive seen it both ways just dont know which is correct i did it once just with 1.0 gauge seemed fine
The correct term is noise floor, and I think you used it out of context.
It refers to the ambient noise in your vehicle.
Including system noise.
i would leave whats there,and add 1/0.
o.k noise floor but not in wrong context have been told that is what it is by a audiocontrol rep i only have it in tweets an is there when system is turned all the way down
juts had same problem i was useing top of the line gear changed every thing amps rca radio no power leads near rca or speaker wires the onlt thing that solved my problem was take .5 farad cap cut power fed from altanator in half under hood place in line noise gone
Your not completely in the right context, but close.
What you have is system noise, and it is causing a higher noise floor.
There is no right fix everytime, what is happeneing is that you are picking up a freq of noise that is higher than the crossover for your mid driver, and therefore only the tweet picks it up.
You can try moving the crossovers, as long as all wiring issues are perfect.
I would hope that your wiring is already perfect.
  • Who's Online   0 Members, 0 Anonymous, 3236 Guests (See full list)
