Getting started on my S10, will be a slow build due to budgeting limits but I'm starting with the Alt.
It's a 2.2l s10 so the stocker has to go and there aren't aftermarket bolt ons that have good idle output...so I'm adapting a DC Power 270 SP.
It's tight and not much room to work with (the alt is friggin heavy compared to stock !! )
I built an extension bracket out of 1/4" steel and just ground it down 'till it fit. It was a bitch getting the top bolt started by myself 'cause I had to hold it in place and sneak the bolt in from the back at the same time.
Here are the pics of my progress so far.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Top bolt mounted measuring the bracket.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Back side of the alt
Frame Ground:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
what's your plans for it? I kno first hand how hard it is to change them alts... they suck. lol
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
Adaptor drilled and bolted on:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Yeah, they really should have put a little more effort into making the standard 4.3 alt bolt up to the 2.2.
Plan is 2 15" RE MTs - cut-through - on a Soundstream XXX 4000d - 14vbats/16v charging
Plans may change though...regardless of the end system I need a beefy electrical foundation :bunny:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Just curious why you would make a bracket instead of getting a mechman 270a made for the 2.2l?
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
Didn't know they made one for the s10 and if it bolt right up I doubt its a beefy as this one. There just isnt enough space in the stock location for a large alternator. What does a mechman 270 made for a 2.2l s10 do at idle?
**edited for spelling
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
165amp at 700rpm-full output at 1700rpm. Not sure what the specs were on that dc power.
Pioneer deh-8300UB
Big 3 upgrade
185ish @ idle
are you sure that mechman would bolt into the stock location on a 2nd gen 2.2l s10 ? What alt casing do they use?
Not that it matters at this point :)
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1161 Guests (See full list)
