Hello I am New to this forum and could use some help.
I bought a new Alpine pxa-h701 to add to my Alpine Iva-W205 but I think it might be broken On the front 1 output it will only play as tweeters not full range. I have tryed everything i could think of but it only will come out as tweeter's.
Also when I first hooked it up When I would fade it to the front the rear would play (I checked to make sure I had the right RCA's in the right place on the EQ and the amp). then later that day out of the blue when i tryed fadeing it to the front it worked and the front only played.
Anyone here have this EQ how is it for you I was also told and read a lot that using the digital cable would be best and that i would tell a big difference from using the AI-net cable from the iva-w205 to the pxa-h701.
And I dont know if it is me or what but when I adjust the eq settings I dont hear a differnce only when I adjust the x-over setting do I hear a differance.
This thing
Thanks
BadBoy
Posted (edited)
This thing
Thanks
BadBoy
I have one and let me tell you, you have a lot of tunning in front of you my friend.
1st of the 1st 2 sets of rca's are just for the tweeters or hi-pass. It's there so you can amp your tweets separately from your mid range.
I use the optical in mine and it makes a big difference over the same setup in the wifes truck without.
Edited by kingsuv
Thanks for the reply
From what the manual says it can be used as both Full range or just tweeters.
What are you using to control the pxa-h701 are you using the seperate controller or are you using a alpine head unit.
Did you have to turn on any settings for the optical or didi\you just plug it in On my setup I only turned on the optical out on the deck and cant find any thing in the EQ setting to change it to get optical in so i am assuming it is working and not still just getting sound from the Ai-net cable.
Thanks
BadBoy
Thanks
BadBoy
You can use it for both hi/full you would have to change the settings in the setup/speakers.
I control mine from a controller not off the head unit as the head unit will limit what settings you can change.
I use the IVA D901 for my head unit. with the optical and the DVD changer with the optical in. All you have to turn on is the optical out on the deck for it to work. You can check the output by looking at the cable head and seeing a little red glow ;)
Posted (edited)
I tried changing the speaker setting to full range and it still only played as tweeter in fact it had no difference when switching between the 2.
I turned on the optical output on the deck but did not know if the EQ needed to turn on anything but I saw no change setting on my deck when in the eq setting's mode.
I think my unit is just bad I talked to the shop today and they are going to order me a new one but it will take awhile because of the holidays.
But I am not sure I am going to keep it I think the EQ might be to much for my little set up But I did like the way the sub's hit with the EQ.
Here is my set up
Alpine IVA-w205
JL 300/4
JL 500/1
2 JL 10w3v3 subs
5 1/4 Boston pro's in the front doors
6x9 pioneer 4ways in the rear.
Thanks
BadBoy
Edited by BadBoy
Here is my set up
Alpine IVA-w205
JL 300/4
JL 500/1
2 JL 10w3v3 subs
Thanks
BadBoy
Yeah like I said, it takes awhile to get it all set. I have about 40+ hours into the setup and tuning of mine, But once it's set you won't want any other EQ in your ride.
40+ hours?... damn bill..
Hell 2 days for the install, along with all the other shit I added. Then I tuned it for the 2 8's I had in the doors and it sounded great, then I just did 2 different 8's with 6's in the doors and it sounds fantastic!
you have to set your slopes to passive iirc
I don't think he can access that from the deck. I couldn't on mine, I had to use the controller
