you have to set your slopes to passive iirc
I looked in the pxa-h701 manual and did not see any thing about swicthing to passive iirc can you tell me where you seen that.
And with controling it from the deck I cant find any thing to swicth it to passive.
Thanks
BadBoy
Guest MegaloManiac
well i dont own a h701. but my cd7k showed me when i was in crossover settings, it let me adjust the slopes, and if i keep adjusting it flatter and flatter(ie 24 -18-12-6-) then after 6db it shows up "passive" on mine...
Hello I am New to this forum and could use some help.
I bought a new Alpine pxa-h701 to add to my Alpine Iva-W205 but I think it might be broken On the front 1 output it will only play as tweeters not full range. I have tryed everything i could think of but it only will come out as tweeter's.
Also when I first hooked it up When I would fade it to the front the rear would play (I checked to make sure I had the right RCA's in the right place on the EQ and the amp). then later that day out of the blue when i tryed fadeing it to the front it worked and the front only played.
Anyone here have this EQ how is it for you I was also told and read a lot that using the digital cable would be best and that i would tell a big difference from using the AI-net cable from the iva-w205 to the pxa-h701.
And I dont know if it is me or what but when I adjust the eq settings I dont hear a differnce only when I adjust the x-over setting do I hear a differance.
This thing
Thanks
BadBoy
where did you put your rca on front 1 or front 2? you should put it on front 2
Distributor of:FIAASUNDOWN PhilippinesPhataudio "mine is louder than yours"
I put it on front 1 at frist but it will only play as a tweeter even when I swicthed it to Full range.
Why Should I put it on front 2 The pxa-h701 manual says that front 1 will play full range just to switch it to full range.
Thanks
BadBoy
Thanks
BadBoy
I have my 2nd set used for full and it works great. I would also try to widen your slope.
Which EQ setting are you in G.EQ or P.EQ?
