fairly new to car audio, 1 18" box help
If you don't know what we are talking about: either stick around and read - you will pick it up. Or post your max dimensions, what subwoofer you are using, what amplifier you are using, and what style of music you listen to.
this we can't help you if you don't speak the car audio language. lol
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
http://www.audioque....oofer_p_25.html
and for a cheap amp you could use this
http://www.ebay.com/...#ht_3445wt_1396
And just make sure you do the big 3 and get a good ground for the amp and you should be ok as long as your not clipping the signal anywhere.
And try to get 5-7 cubes tuned anywhere from 30-35hz
and you can use the re audio box calculator even though its not the most accurate it should work to get you in the ball park but tune a little lower with this in order to cover for the sub displacement.
i was just looking for the literall box dimensions. the height width and depth. all the other specs i would have custom made based on the subwoofer that i would end up with
how is audioque i dont know if ive ever came across them before i havfent listened to any of their products
you can make it 36Lx20Hx24D wit a 5 inch slot port. will be 6-7 cubes and tuned between 30-35 hz
so at those dimensions that would be a good set up for the box? because basically with this post i just wanted to know if a proper box could be done in the limited space i have. the lenght im pretty sure i have height i know i have and the depth is perfect i think
Me personally i love Audioque. great subs at a great price point. but just like all things some will like them and some won't. but if your coming from main stream products then a 18 inch AQ sub will bring you a smile from ear to ear.
oh and also what other budget 18 would you suggest because alot of people say audioque i just want to see if theres anything else out there. at maximum id spend 400 on it, i wouldnt like to id much rather settle for 350 but is there any other 1k+ decent 18 for 400 or less?
yeah if that box will fit then you can do a 18. and you can tweak the size a bit and still be good to go.
