Snailblazin' Posted May 1, 2012 Report Posted May 1, 2012 I just picked up this sub and stuffed it in an off-the-shelf ported box that is too small (1.4^3 ft) and tuned too high (~48hz) and I was sort of underwhelmed by its performance. I checked with RF and they recommend a 1.25^3 ft sealed box, does anybody know if this figure is accounting for woofer displacement? Has anybody done something different that makes this speaker come alive? Thanks
getlocivic Posted May 1, 2012 Report Posted May 1, 2012 actually i have ran a t1 series 12 before in more like 2.2 cubes net tuned to 30hz on a audiopipe 1500d 14" of port per cube.. rockford specs are just horrable they ported design they give its like 10" of port per cube and still tuned wayyy high
01VWGREENMACHINE Posted May 1, 2012 Report Posted May 1, 2012 i have 2 of the t1d212's if they are in the right ported box they sound amazing the 2 that I have shake my neighbors windows 5 houses down from mine i would build a box about 2.75 cubes after displacement and port but its up to you http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
Kyblack76 Posted May 1, 2012 Report Posted May 1, 2012 I can just toss in what I've got rolling. The recommended tuning (IMHO) may be high, upper 30's, and I'm around 36. And if I could do it again, I would also tune lower. Low 30's, as I'm not upset by the performance, but not warm and fuzzy about it either. Just my 2 cents SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted May 1, 2012 Report Posted May 1, 2012 i have 2 of the t1d212's if they are in the right ported box they sound amazing the 2 that I have shake my neighbors windows 5 houses down from mine i would build a box about 2.75 cubes after displacement and port but its up to you Hey bro, can I ask what your tuned to? And are you at 2.75? I'm at 3.8ad, and upper 30's...where are you ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
