velvetsmack Posted May 2, 2012 Report Posted May 2, 2012 hey guys i planned on getting a 18" Fi Bl and i would like to know what dimensions and specs to get the box. im not good with descifering (or spelling) subwoofer data so to make it easier for you guys to help me i got the data for the sub off the fi website. Fs: 33.2 Hz | 33.2 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.82 | 5.82 Qes: .32 | .32 Qts: .30 | .30 Mms: 302g | 302g Cms: 0.88mm/N | 0.88mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 181.0 l | 181.0 l Spl: 94.1dB 1W/1m | 94.1dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm Rms: 1500W * | 1000W * Sealed box: N/A cuft | N/A cuft Ported box: 5-8cuft | 5-8cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 9.750” * | 9.750” * Displacement: 0.26cuft * | 0.26cuft * i havent learned how to desipher that^ yet so can anyone tell me the dimensions / specs of the box? also the max i have to work with i think is 30h X 28d X 36w and if i can find a box online for this sub if anyone can point that out too would be awesome. i live in a redneck town unfortunately, no one here could make a custom box and neither can i.
velvetsmack Posted May 2, 2012 Author Report Posted May 2, 2012 I got a Kia Rio hatchback, so I have the room. My max dimensions are like 36 across by 30 high and like 26 deep As for the amp I have to get another because my current amp will underpower the 18 greatly so probably a budget monoblock thatll put out like 1200watts And I listen to rap and dubstep.
velvetsmack Posted May 2, 2012 Author Report Posted May 2, 2012 The back seats folf down and it becomes a longer flat surface
Jdubs04ss Posted May 2, 2012 Report Posted May 2, 2012 I got an Sundown SAZ-2500d or a Black DD M3a if you needed a more powerful amp 2004 Impala SS (2 Tone) Kenwood DDX-512 (Nav,XM,Bluetooth,Ipod) Optima Yellowtop 240amp PB Alternator ZZP S2 Volt Booster Stinger SPV70 Battery(Trunk) Big 3(x2) Monster 1/0 50ft Monster P400 1/0 Monster I401 2C-4M RCA Memphis 16-VBF1 Line Driver Memphis 15-MCC6 6.5" Comps Memphis 15-MC92 6x9" Rears 15" Memphis CM Mojos Custom 4.3cube @32hz Enclosure Digital Deisgns M3a(Black)[email protected] "Yes I hear you...But can you feel me?"
