Luda Posted November 3, 2006 Report Posted November 3, 2006 I just swapped my dieing RF 8002 w/ a Kenwood KAC 9102D, should be about 300W mor because my RF was down to one channel. so probelm 1, i dont feel the bass as much, i dont have access to a Mic so i cant tell if it is as loud, but it doesnt seem like it, im thinking it is because of the sub sonic filter @ 25Z, the RF didnt have one. problem 2)the amp is cutting in and out of me. at first it was the secondary ground [lil screw to the left of the RCAs labeled GND] hooked that up and its all good. going down the highway to day it cuts off, comes back on a couple minutes later, cuts off, comes back on. i couldnt associate it with any certain movement or anything... im @ a complete loss... any ideas? Quote 2005 Grand PrixSource: StockFronts: Stock 6.5 ComponentsRears: Stock 6x9Subwoofer: FI BTL 12" Fully optionedSubwoofer amplifier: Kenwood KAC-7203 bridged @ 4ΩEnclosure: 3.41cuft tuned to 33hz
bassmachine Posted November 3, 2006 Report Posted November 3, 2006 what kind of car do you drive and where is the amp located in the vehicle. Quote Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
Luda Posted November 3, 2006 Author Report Posted November 3, 2006 its a chevy celebrity, trunk. and its barely warm to the touch, im gonna go drive it and see if i can figure it out. but any got anyone got any ideas, i have 2GA wiring running back, and a solid body ground, sanded off, etc. i think my RCas my be going out on me, so im going to go check on that. Quote 2005 Grand PrixSource: StockFronts: Stock 6.5 ComponentsRears: Stock 6x9Subwoofer: FI BTL 12" Fully optionedSubwoofer amplifier: Kenwood KAC-7203 bridged @ 4ΩEnclosure: 3.41cuft tuned to 33hz
ChevyBoy Posted November 3, 2006 Report Posted November 3, 2006 could be ur rca's, or it could be ur rca connections on the amp, or ur rcas on the head unit Quote
Guest MegaloManiac Posted November 3, 2006 Report Posted November 3, 2006 could be the amp isnt stable at whatever ohm you're at, or the rca's have a pinch somewhere, or your gains are too high, maybe a bad ground Quote
ChevyBoy Posted November 3, 2006 Report Posted November 3, 2006 i would definitely change out the rcas. cause u mentioned that the fosgate amp lost a channel. and this amp u just put in there aint workin. so i think thats the first thing u needa worry about Quote
Guest MegaloManiac Posted November 3, 2006 Report Posted November 3, 2006 use your DMM on the rca's to check em. outside ring is ground/neg and the middle prong is pos Quote
S12X Posted November 3, 2006 Report Posted November 3, 2006 are you sure the fosgate amp even lost a channel if you think your rcas are bad??? are both channels on the kenwood running? sounds like its a good possibility its your rcas Quote new setup in the works
ChevyBoy Posted November 3, 2006 Report Posted November 3, 2006 try swapping the fosgate back in and try "reversing" ur rca's. red to left and white to right. Quote
