Great looking build! I wish I would have taken more time on mine.
2003 F-150 Single Cab
Pioneer 80prs
All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs)
Sky High Fuse holders
Big 3 with redtop
Karma SS RCAs
Eclipse EA4000 for Mids
Rockford Fosgate Punch Pro 6.5s
Crescendo RTS-1 tweets
Audio Technix AT1200.1d for Sub
Soundqubed HDS312
Box 2.65cubes @ 32Hz 6'' Aero port
Stock 130 Alt (looking at a Singer 270 Alt)
I'm keeping all the "factory" stuff too. I have not cut one connector from the factory harness. I just tape them out of the way, or remove that section (like the door section) and save it. I can always put things back the way it came. Not sure why I would want or need to, but it's possible.
Here are some pics of the door pods and misc. wiring photos.
The seal colors are different for different size wire. Yellow is bigger than orange. ;)
Door pods wired up. In case you're wondering what the 4 wires are, 1 set is the signal obviously, and the other is the for the tweeter. The crossover is built into the 6.5. I thought that was kind of cool. No extra box to mount/hide somewhere.
Installed
Starting working on the trim pieces today, and then this project is a wrap. I got the "wire cover" done so far. I'm going to try and knock out the side trim pieces this evening.
quick question, where did you get those female/male plugs for the factory molex plugs? I did a quick search a while back and couldn't find anything. Got a link by chance?
formerly known as Blue86f150
this sux camel dicks
