KenC210 Posted May 4, 2012 Report Posted May 4, 2012 So i just curious if my deck sets the sub LPF and i set it at 80hz would it really matter where the LPF on the amp is just as long as its not under 80hz or should i still try and get it close to that point? I know i still need to set the subsonic i just curious more about LPF. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Guest Posted May 4, 2012 Report Posted May 4, 2012 So i just curious if my deck sets the sub LPF and i set it at 80hz would it really matter where the LPF on the amp is just as long as its not under 80hz or should i still try and get it close to that point? I know i still need to set the subsonic i just curious more about LPF. correct
KenC210 Posted May 4, 2012 Author Report Posted May 4, 2012 So i just curious if my deck sets the sub LPF and i set it at 80hz would it really matter where the LPF on the amp is just as long as its not under 80hz or should i still try and get it close to that point? I know i still need to set the subsonic i just curious more about LPF. correct Thank you for clearing that up i thought thats how it worked just wasn't to sure Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Jessica Posted May 4, 2012 Report Posted May 4, 2012 I'm glad you asked this because it brings up another question too. I'm not trying to thread jack. This question relates to your question. I wonder if say both the amp and h/u had 18db/octave slopes would that be in effect an 36db/octave slope or do you lose some attenuation when a signal is already attenuated. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
