3 lines is ground.
L is the load. aka the amps
12+ goes directly to battery
haters is wrong.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
I fucking ninja'd y'all about me being wrong already. Ha.
Ninja count:
Me - 2
Kranny - 6,347
I'm catching up.
Yeah, I got it by what you guys said I appreciate it. The diagram above is to LED's but I need to use the H/U's remote wire, so I need to bring that wire to the 12vout, and another wire going from the amp to the 12v out right? So two wires into the 12 volt out? If i just hook the amp's remote up to the 12volt out it's obviously not going to get signal haha so I'm curious as to how I go about this.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
if you wanted to avoid having the light work at all you can simply split the remote wire and connect one side to the center pin and one side to the B+ pin. Id do it the other way but this will work too.
Why wouldn't I want a bright shiny light? :D
Lol just giving you options. But its good to see indication that the amps on
In the diagram, just replace "LED" with amp lol. That simple ;)
Remote wire from h/u going into the B+ side. Remote wire coming off of the middle one on your switch going to the remote on the amp. Third terminal goes to ground.
No the headunit remote wire should go to B+ then the center pin or L should go to the amps remote turn on terminal. The ground is just the ground.
  • Who's Online   0 Members, 0 Anonymous, 2075 Guests (See full list)
