Anti-Corrosion product before crimping?
no crimping for me, just use rossin core solder and good to go
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
Don't put anything on the wire before crimping. The idea is to cold weld the wire. Since it is all fused into one piece, you don't have to worry about corrosion. But if you try to crimp a greasy wire, I can't see that going well. Think of it like this: You put oil in your engine so it doesn't sieze, when you crimp - you are 'siezing' the wire in place per-se. Seems like any sort of grease / oil / contaminant will just inhibit that process.
Just get some weatherproof (adhesive lined) heat shrink and call it a day.
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
