DC Sound Lab
Ok I seen a post like this somewhere but cant find it...
Ok if I got this rout & get a blown dc lvl 4 m1 can I use a dc lvl 4 m2 recone kit??
If that works with no problems... Will that sub(s) cause any problems if I put it in a box with a all stock dc lvl 4 m2???
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
You should beable to. But that doesn't mean its on the same level as a m2. They're not just better soft parts, the motors where completely redesigned.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
i have 2 m1 lvl 4 motor/ baskets with m2 recones. they run great. its the same just upgraded to the flat wound coil. rms is around 1000 to 1100 i think... but dont quote me on that.
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
I know there not the same, they can all handle the same watts but if i put them in the same box will it cause problems or noticeable audio
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
Good to know... Not I can get the blown m1 lvl 4 motor/ baskets for the extra low.
Still need to see if putting them both in the same box will cause problems...
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
well you can put them or it in the same box as before and be fine... if thats what you mean...
... BUT DONT put a full m2 lvl 4 in the same box WITH a sub with an m1 motor and m2 recone.
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
I wOuld definitely recommend gettin the new level 4 recone. The new 4 coil is a flat wound coil. The old level 4 coil is now used in the level 3.
KOOL!!
Will two m1 lvl 4 with m2 soft parts cause any problems or noticeable audio difference if I put them in a box with two all stock dc lvl 4 m2???
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
KOOL!!
No DO NOT do that. They will act differently.
KOOL!!
Well there goes that plan
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
  • Who's Online   1 Member, 0 Anonymous, 1397 Guests (See full list)
