Help with Aero port's??
Ok well I designed my box for my 2 AQ HDC3 18's with a slot port tuned to 33hz. But now I'm considering using Aero Ports instead. Would like to have it tuned between 32-34hz for daily and be able to switch 50-55hz for burps. I don't want to dip below 200 square inches of port. But I'm not sure how to design it without losing port area. I haven't done a box with areo ports or an interchangeable port yet. This will be going in my 99 Tahoe. Any help is appreciated.
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
you dont need the same port area with aeros as you do with slot port
also there is prolly 30 threads about this maybe they have a better answer there
Oh I didn't know you the port area didn't need to be the same. Thanks.
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Due to the efficiency of qeros u can less areq with the same output. I say run th same amount of area with aeros that way u aren't defeating the whole purpose to begin with.
Owner of BigAss Ports
  • Who's Online   0 Members, 0 Anonymous, 612 Guests (See full list)
