velvetsmack Posted May 6, 2012 Report Posted May 6, 2012 hey guys i want to get a 18" fi bl and run and strap 1200 watts to it for daily use. the specs i will include below, can anyone give me a box design? maybe using the torres calculator and post a picture? thanks guys! Fs: 33.2 Hz | 33.2 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.82 | 5.82 Qes: .32 | .32 Qts: .30 | .30 Mms: 302g | 302g Cms: 0.88mm/N | 0.88mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 181.0 l | 181.0 l Spl: 94.1dB 1W/1m | 94.1dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm Rms: 1500W * | 1000W * Sealed box: N/A cuft | N/A cuft Ported box: 5-8cuft | 5-8cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 9.750” * | 9.750” * Displacement: 0.26cuft * | 0.26cuft *
Joe X Posted May 7, 2012 Report Posted May 7, 2012 Post your max dims for the box, amp and vehicle models and type of music you listen to.
velvetsmack Posted May 7, 2012 Author Report Posted May 7, 2012 max would be around 35 wide 24-26 tall and 24 deep i would use for daily driving, listen to dubstep and rap. i have to purchase a bigger amp for this new sub but im gonna buy some 1 ohm stable mono thatll give me 1000-1200 watts perferably 1.2k and i drive a kia rio hatchback so space isnt exactly that much of a problem it would take up pretty much all of the back but the seats go down and it turns into a flat surface
