Hey guys I have a slight problem but I have no idea what it could be.
I checked the powers and grounds on my big 3, powers and grounds on my rear batts, amps, everything and nothing seems loose or corroded. Charged my batts and issue still persists.
So here's the thing, when I turn my car on and have it sitting my voltage is good, when I'm driving my voltage is good, BUT when my car is in gear and and I'm at a stop my voltage drops into the mid 12s. It does that even if nothing is on (stereo, light, etc)
What do you guys think it could be?
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
your rpm is probably low
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Wouldn't rpm stay the same at idle on Park and at idle in gear? Or does that change?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
RPM usually goes down a little bit when you put it in gear. Have you checked alt output at the voltage regulator?
What is your idle rpm.
Battery = XS D3400
Sub= Kicker L7 12"
I haven't checked my output since I got my alt from Mechman last year.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Not sure, my car doesn't have an RPM gauge.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Go ahead and check your output voltage. The regulator might be going bad, or if it's adjustable, just adjust it.
Sounds like what he said... when you put it in drive and sit there your rpms are too low for the alt to turn on...
If it just started doing this but didnt before... One of two things.. Either your rectifier is going out or you have some batteries pulling more current than they used to before. Like they are going bad or need to be charged overnite.
What could cause the rectifier to go out? Especially this fast, it's only been about a year and the car gets used like 1 a month if that.
I already tried having the batts on a charger over night, I'll try it again though.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
  • Who's Online   0 Members, 0 Anonymous, 823 Guests (See full list)
