Voltage is more than likely 100 volts in
Summed sine voltage would be 200v peak to peak.
Or if it says its a 200v input than peak to peak would be 400v ~
They are giving you everything you need to know to answer any question.
Current
Voltage
Loss to heat
Actual energy output
Freq
Phase angle is something i know about and how it works but not the math to figure it out.
Or, maybe i missed the actual real question here.
sorry ray, it is not, I have to find the circuit impedance, current flowing, potential difference across the resistor and inductor, and the phase angle between the voltage and current.
If you really know ohms law than you know the impedance, current
Im actually at the hospital or id figure out phase angle.
Break it do to the basics man.
Seems stupid simple to me.
Take a pic or the actual question???
Phase angle.
Fixed for the given freq
Then add for the slope of the circuit itself at that freq.
http://www.sengpiela...edelayphase.htm
easy now dont want to scare people away lol
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
for the impedance I did this:
Z=Sqrt.*(R^2+(Xl-Xc)^2)
Z=Sqrt.*(100^2 + 628^2)
Z=636 ohms
current flow I did this:
R=V/I
R=200/2
R=100 ohms
Potential difference across the resistor and inductor:
The phase angle between the voltage and current:
Vin^2=Vr^2 + Vl^2
where Vl = I * Xl and Vr = I * R
I think that is the right formula
I will type it out for ya.
A coil consists of a resistance of 100 ohms and an inductance of 200 mH. if an alternating voltage v, given by v= 200sin500t volts is applied across the coil, calculate
(a) the circuit impedance
(d ) the current flowing
(c ) the potential difference across the resistor and inductor
(d) the phase angle between the voltage and the current
thanks for the help, sorry if I come across rude, I am not.
Edited by Dubpower
Iget 141ohm
100v
100v
1ohm
Your calculations are off.
Uhh.
What book are you working out of??
103?
Heres the worksheet from electronics 103
no book at all, just work sheets.
ah now I see it, I got the hole thing wrong. thanks for the help ray ya legend!
Edited by Dubpower
  • Who's Online   0 Members, 0 Anonymous, 2146 Guests (See full list)
