Smurfboy Posted May 8, 2012 Report Posted May 8, 2012 For some reason, I am starting to second-guess myself wether I'm buying the right version of 2ohms or 4ohms. Currently, I have two S10"L7 (4ohm) powered by a KX1200.1. I'm about to order two more S10"L7 as well; since ZX2500.1 is stable @ 2ohms, I just wanted to make sure I'm buying the right ohm for subwoofers. Am I looking at the right wire (see picture belows)? Thanks so much! (I searched for answers in other topic but no luck thus far).
aleroking Posted May 8, 2012 Report Posted May 8, 2012 For some reason, I am starting to second-guess myself wether I'm buying the right version of 2ohms or 4ohms. Currently, I have two S10"L7 (4ohm) powered by a KX1200.1. I'm about to order two more S10"L7 as well; since ZX2500.1 is stable @ 2ohms, I just wanted to make sure I'm buying the right ohm for subwoofers. Am I looking at the right wire (see picture belows)? Thanks so much! (I searched for answers in other topic but no luck thus far). yes this diagram is correct if you want to run your amplifier at 2ohm nominal then yes run 4 4ohm dvc subs 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
Guest Posted May 8, 2012 Report Posted May 8, 2012 just make sure you have electrical upgrades. thats an almost 3x power increase. and adds 3x more stress to your alt and batteries (notice plural)
Smurfboy Posted May 8, 2012 Author Report Posted May 8, 2012 Yes, I am aware of it and will definitely do the upgrade big time. I will also do the big-three as well to keep all things happy.
