ok if you hook straight up positive to them do they work?  If so then use relays and trigger them with the wire that would have gone to the bulb.  Thats what i do.
Follow my Tweet (Twitter)
Got it working  8)
I had to cut the positive of the turn signal so when I turn the lights on (just the signals, orange bulbs, no headlights) tied them together and tied them together using electrical. Did the same with the negative of the turn signal (that was it's ground).
It was really confusing though because who ever made this car was completely retarted. You would expect each wire to be the same but no. Right wires that were positive were green and orange and on the left side yellow and blue. Only thing was that both sides had black negatives so that helped (a little).
This allowed the projectors to get the "halo" effect working. Now my lights have the halo effect when I have them in one.
Then I had to do the same thing with the + & - of the HIDs. Was pretty easy after that. Now the HIDs turn on when I switch it into "two" and the halo effect is still on with the high beam surrounding..Looks pretty cool imo.
I will get some pics for you guys :)
Guest SyKo13
ahahahahaha, retarded people building cars :D, now that's interesting lol, other then that, good job lol ;D
LOl seriously..I knew if I built the car I would more than likely match the wiring...
Also it was the only thing I could think of that may have worked.
