Kicker S15L7 In 1980 BMW 728 HELP !
Haha ok i will turn those down... all the way ?
Checked the internet
and found the total capacity of the trunk which is 480 Liters
metal plate behind the rear seat:
https://www.dropbox....9h/Naamloos.png
Ive already cut a hole on the red lines
Planning on cutting on the green lines an screwing an MDF plate on it.. Good idea ?
Trunk Dimensions (in CM)
https://www.dropbox..../Dimensions.png
Nah don't turn your gain all the way down. Just your bass boost. I would look into getting a DD-1 so you can set your gains properly and not have any distortion. Totally worth the money in the long run.
OP you list a single amplifier for the sub, so the speakers are being run directly from the head unit right?
If so the distortion you hear on them has nothing to do with the sub amp settings.
X2
I'm just trying to save your woofer and if you get a different for your speakers then the DD-1 will help with that also.
Thats right but somehow the speakers cracks on low and hi volumes.
And for the SUB its still wired in series so it's playing on 8 ohms right ?
  • Who's Online   1 Member, 0 Anonymous, 1082 Guests (See full list)
