Mikey Bates Posted May 9, 2012 Report Posted May 9, 2012 My deck only have front and rear/sub outs. would it be smarter to go from my front and rear to the front and rear on my 4 channel and then the 4 channel out to my mono? that way i would still have control over all four speakers instead of using y splitters on the front channel and then using the rear as the sub. the 4 channel is going o be a skar audio sk 85.4. link here http://www.skaraudio.com/index.php/productscatalog/amplifiers/item/sk-854.html?category_id=6 thanks
ALPINE408 Posted May 9, 2012 Report Posted May 9, 2012 yes you have an output on that amp that can go to the imput og your mono block its called dasiy chain Have you ever had your woofers blown?
Jessica Posted May 9, 2012 Report Posted May 9, 2012 Grammar fail edit* If you do that then you are still going to have your subs on your rear channel most likely, and then you wont have subwoofer level control. I would just split the fronts then run the rear/sub to the subs if it were me. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Mikey Bates Posted May 9, 2012 Author Report Posted May 9, 2012 Thanks! That was my thought, i just wasn't sure if it was ok but thanks man
Mikey Bates Posted May 9, 2012 Author Report Posted May 9, 2012 Grammar fail edit* If you do that then you are still going to have your subs on your rear channel most likely, and then you wont have subwoofer level control. I would just split the fronts then run the rear/sub to the subs if it were me. I do have a bass gain, so haveing the sub volume on my deck and bass gain is really just excessive
Jessica Posted May 9, 2012 Report Posted May 9, 2012 Grammar fail edit* If you do that then you are still going to have your subs on your rear channel most likely, and then you wont have subwoofer level control. I would just split the fronts then run the rear/sub to the subs if it were me. I do have a bass gain, so haveing the sub volume on my deck and bass gain is really just excessive You mean a separate knob for the amp level for your subs? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Jessica Posted May 9, 2012 Report Posted May 9, 2012 Ok, Well the only issue is see is you might find fading to front/rear might fade away from the subs also depending on how the pass thorough on the 4 channel amp works. Let us know how it goes. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
