RE AUDIO RSX or RS subwoofers ? not sure what i got!
so i have 2 12'' RE audio subs and not sure if they are just SR or SRX i can not find info on a RE audio SR sub.... only SRX and when i look on RE audio web site it shows that the SRX are only DVC4 , got them from a guy online he said they are DVC 2ohm but he was not sure what they were 1st he told me they were RS then he told me they were RF and then RE so when i got them they have SR on the sub! they look like the SEX subs on the website and not the SRX so i dont know if there was a SR then later a SRX sub. also told me he was runin them @ 1ohm and later he said @ 2ohm lol so i need some help in finding out what they are and if they are DVC2 or DVC4 and the watts on them. i have them on a powerbass ASA.2000.1 i have to look and see if they a ran in series for 2ohm. i think they are runin parallel at 1/2 ohm cuz the amp cuts out sometimes for just a sec at a time so i need to look. so hlp would be good if someone knows the re subs thanks .
Edited by sbg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
still dont know what they are
Edited by sbg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I ran the SRX's and before THAT they were called SR's. The cone should tell you if they are SRXs or not. Its printed in the low middle of the sub. Please post a pic(upload to photobucket and then copy the img and past here in this thread). Im curious to see what you've got there. Hopefully not a TURD
so i have 2 12'' RE audio subs and not sure if they are just RS or RSX i can not find info on a RE audio RS sub.... only RSX and when i look on RE audio web site it shows that the RSX are only DVC4 , got them from a guy online he said they are DVC 2ohm but he was not sure what they were 1st he told me they were RS then he told me they were RF and then RE so when i got them they have RS on the sub! they look like the SEX subs on the website and not the RSX so i dont know if there was a RS then later a RSX sub. also told me he was runin them @ 1ohm and later he said @ 2ohm lol so i need some help in finding out what they are and if they are DVC2 or DVC4 and the watts on them. i have them on a powerbass ASA.2000.1 i have to look and see if they a ran in series for 2ohm. i think they are runin parallel at 1/2 ohm cuz the amp cuts out sometimes for just a sec at a time so i need to look. so hlp would be good if someone knows the re subs thanks .
As far as your wiring goes, if you have all the positive from the coils hooked to the positives for the amp, and the same thing with the negatives, you are running in .5 ohm. Please re-check how you're wired and change it if there is a problem.
they just say SR on the cone small and they are good subs even if they are just sr's they are hiting at 145.3 i am runing them at .5 ohm but thats not why my amp was cuting in and out 1 of the wires inside the box was jacked up. my amp runs good at .5 does not even get hot at all also have a planet audio ap 1500d i use on the subs at .5 and never have a problem with that amp to so its all good. i will try to post pis of the subs.... from what i was told the older RE audio stuff " SR" were a better sub then the new stuff."srx"
Edited by sbg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
photo.jpg Edited by sbg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   1 Member, 0 Anonymous, 1107 Guests (See full list)
