SA-15's Enclosure help
im just going to build a ported box inside of my trunk. Box Design H- 17 W- 38 D- 25, Port height- 15.5 port width- 4.5 port length- 19 physical port length- 18.25. sub displacment is .34, bracing displacment .2. the box is right a 6.05 after everything is said and done. its tuned at 33hz. what would be the cut sheet cause torres cut sheet is confusing. It says the front peice is 38 wide but shouldnt it be 32.75? cause the port is 4.5 wide and the would would be .75? juat need a little help on the cut sheet. thatnks huys.!
We don't have alot of neighbors so we can blast the stereo.
Sounds like just enough air space for those 15's. You might not have the absolute best lows as they can, but better than the sealed enclosure. You'll probably like it best facing rear, unless you want to seal off the trunk. Good luck man!
Edited by BobbyG2
*New vehicle and system coming soon.*
I suck with cut sheets, but there's loads of people here that have mastered it. A lot of people recommend Torres box calculator, it's linked in a sticky here in the sub/enclosure section. Read up in that thread and in the programs help file
Right, so here is a cut sheet, all across double baffle:
Enclosure Specifications:
External Height = 17 in
External Width = 38 in
External Depth = 25 in
Port Width = 4 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 38 x 17
Left & Right Sides = 22 3/4 x 15 1/2
Top & Bottom = 38 x 22 3/4
L Port Internal Assembly Parts:
Front to Back = 17 1/2 x 15 1/2
  • Who's Online   0 Members, 0 Anonymous, 1384 Guests (See full list)
