thanks. and right now my problem is i dont have a battery post to mount to... should i take the stock charge wire off the alt and battery and replace it with the 1/0 and use ring terminals? i need help but idk what ill need. i need alt to bat, bat to ground, bat to amp, amp to ground. thanks for any info
and or products that ill need
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
You need ring terminals and heat shrink tubing. When I replaced the power/ground under my hood I picked up 5 packages of Monster ring terminals with included heat shrink and ended up with a couple extra. They worked great and my 4awg wouldn't budge even if you tugged on it. If you have any 4awg cable laying around, that's my recommendation.
http://www.sonicelectronix.com/item_18329_Monster-Cable-MPC-P200-RT4-3.html
If you prefer to use your 1/0 under the hood, pick up some heavy duty ring terminals from the local hardware store, and grab some heat shrink. The Xscorpion stuff is legit ;]
http://www.sonicelectronix.com/cat_i230_tubing.html
2007 Chevy Silverado Classic 5.3L w/ Brutus 1700W, NVX 4 Chan, L7 Subs, Sony Deck & Alpine Speaks
Sonic Electronix Articles by Harry Donihue --> CLICK
  • Who's Online   0 Members, 0 Anonymous, 1372 Guests (See full list)
