ok so i now need to order ring terminals and battery post connectors. when doing the big 3 should u keep the stock wire from alt to bat? mines all frayed and the one on the bat is taking up the whole post. so what im asking is what do i need to run big3 and amp lines? running big3 in xscorpion flat 1/0 and amp in kicker hyperflex 1/0. not sure what i need at all please help
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
oh and where do i need to run voltmeter to for now? since im not powering the amp up yet since it wont push anything for a few weeks
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Not exactly sure about your question, but this might help.
With the big 3, you're not replacing your stock wiring. You're adding to it. Leave your stock wiring in there, and just add the 1/0 runs on top of that. Get some ring terminals for the wire you use for the big 3, and new battery posts that has a bolt you can attach the ring terminals to. That will solve your connection issues.
Voltmeter goes like this.
Positive to wherever you want the readout from (I.E> battery or amp)
Neg to ground
And then the remote turn on to any switching power source.
Edited by Cardboardcat15
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Just run the wires to where your amp is going to be and leave it disconnected till then. When you install your amp, connect the voltmeter to your amp.
Neg to ground
ok so what would a remote be its a xscorpion one 2 wires only? and can u replace battery post on flooded? its a old pos in there but $0 to upgrade as of now. and sits at like 14.2-14.8 on my in dash stock meter, ill check with dmm when i have time.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
id like to see what it runs at now cuz i know the battery drains like hell just from sitting in it listening to it for like 10 mins with just the speakers and hu
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
and so i need 1/0 ring terminals. battery post extended, heatshrink? anything else im forgetting?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Well shit it doesn't have a remote turn on? You'll either need to wire it with a switch to the battery, or to an acc wire or something.
^^^ what would u suggest running it to on an acc? run it radio?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 1671 Guests (See full list)
