running my electrical.
damn. thats gonna be a bish to get back to some of them. the only ones i remember was battery to ground ones and the amp ground but i crimped them both enough to where they wouldnt pull out
still redo?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
After your connections are soldered right and cooled you should be able to put that terminal in the vice and pull the hard on it and it should stay together. You have to be confident in your connections, why fry an amp because of a $2 part and a 5 minute fix.
ok so how can i fix them now? cut off heatshrink and just heat and more solder? then re apply shrink?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
yes
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
I fill that sucker with solder. let it cool then heat it back up so it sucks the solder down in the connector. I use lugs though and it's easier they are closed on one end.
damn... i really hope the ones that are bad are the easy to get to ones... dont feel like unbolting my pulleys again...
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
what u mean lugs?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I have replaced customers amps from loose connections so be a good investment in your equipment to have solid connections.
Evo X build log
dang. i guess i gotta accept my stupidity then. but are they important if they just the big3 ground stuff?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
