well im wanting to sell my amp to i can buy a bigger one and i know they sell for alot of money but i dont know where to sell it at ive tried craigslist no luck no one around me has money to buy things like that.
Its only worth about 300 on the street.
I usually buy them for 100-125
Damn! You should give me your hookup. lol
Edited by eltortuga94
System:
Basically Stock
In process of upgrading
shit ill buy yours for 125 lol..... 125 shipped that is :D
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
How much are you looking to sell it for?
(Also, I think this is classified as a BST thread, and will be closed fairly quickly...)
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
I paid 200 once.
They are fantastic amps if you know how they work and run them in the best manner.
Very tricky stuff they can do.
Almost need a scope hooked to them 24/7 to make sure they arent throttling down.
Enough secrets...
I paid 200 once.
Enough secrets...
SECRETS. YOU CANNOT STOP ONCE YOU'VE STARTED.
Think of it as a 3spd transmission.
It will downshift if the Rail voltage gets to low
Rail voltage on a transformer based amp goes down when input voltage goes down and current goes up.
Once the amp "downshifts" it stays there, it does not have a circuit to make it upshift.
This is very similar to how the rf bdcp amps work.
I know a couple guys that may or may not be thinking about making a bdcp killer.
Class a/b that can upshift.
Ok, thats enough.
So low voltage makes it drop down in output...how do you get it back up? Turn it off then back on
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yes
