Doing the big 3 x2?
I was wondering if doing multiple runs in a big 3 such as 2 runs from alt to bat and 2 runs from bat to ground etc. would that be better than doing 1 run? or would it not make much of a difference?
Thanks
single alt should be find on a single run of 1/0 for big 3. Unless you have a battery in the rear and the alt upfront. Then maybe I would do a 2nd run for the ++. The distance plus engine and car heat will increase the resistance on a single run. If everything is under the hood and you are running a single alt then I wouldn't bother. If you still have issues after the big 3 in 1/0 you will want to start looking at upgrading other hardware or adding a 2nd alt if possible.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Simple to figure this out, first ask yourself how big is my alt? Is it over 300 amp? If not then one run of 1/0 is plenty, but if you have more amp output then what the cable is rated then add more wire or bigger wire. Just like running power wire for an amplifier.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1978 Guests (See full list)
