if you want to keep the same box, and if its a box problem, put 10" sono tubes behind every sub that are at least as long as the sub is deep. im not sure what length would be best though. that will help even out the pressure behind each sub.
thats what next.. apparently it helps alot and usually gains quite a bit, even tho its not built for numbers
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
doublecheck all subs and wiring
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
wiring has been more then tripple checked lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
if you have access to a TL it might be interesting to look at the scores in different places inside the box. that would tell you if you are getting a ton more pressure in one area than another. might help you understand what is going on.
I do have a TL here, The thing that gets me,is the SA10s were fine, and they were getting quite a bit more power
Where should i place the TL? I dont want to keep playing it when the "problem" is happening, as im sure its not very good for the subs lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
dont do it at full tilt. just place it anywhere in the box, multiple places though. its just an idea to be able to look at pressures inside the box. nothing ive ever done but i would imagine it will help you understand what the problem is, if the box is indeed the problem.
i shall give that a try! i do need to rebuild baffle soon.. but it will still be either port accross top or some type of clamshell.. no side ports for me..
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
^this. Cross directional loading was my first guess.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
still does it with 6 not hooked up, which eliminates it as a loading issue
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
