Whats going on guys I just got a Orion hcca 102 {10" dual 2 ohm) I got it sitting in my old box that I made for my alphasonik 800 series which is about 2ft^3 just so I could use it now, my question is how many cubes would you guys recommend going with? Its going in my 08 lancer and is a daily driver. I tried searching this forum and google but came up with nothing. I felt orions spec was to small cuz its calling for half the size it has now and I feel like its too small as is right now. Also how wide should my slot port be? Its a 2" wide tuned to 35-36hz right now... Thanks for the help guys
Factory double din navi unit with 30gb internal
Crescendo bc3500
DD 9512i
hey dude here some specs of the HCCA 10.2
SPECIFICATIONS
Directed Part Number 27302
Model Number 10.2
Thiele/Small Parameters
Fs (free-air resonance, Hz) 30.78
Vas (equivalent compliance, cu. ft. 0.564
Vas (equivalent compliance, liters) 15.98
Qms (Q, mechanical) 3.63
Qes (Q, electrical) 0.42
Qts (total driver Q) 0.38
Re (DC resistance, ohms) 3.93
Z (nominal impedance, ohms) 2 x 2
Le (inductance, mh) 1.93
Efficiency (1W @ 1M, dB) 83
Xmax (one way linear excursion, in.) 1.0
Xmax (one way linear excursion, mm) 25
Pe (continuous power handling, watts) 1500
Peak power handling (music, watts)** 3000
Mms (total moving mass, grams) 261.93
Cms (mechanical compliance, mm/N) 0.102
Bl (motor strength, Tesla-M) 21.81
Sd (effective radiating area, sq. cm.) 333.3
Sd (effective radiating area, sq. m.) 0.03333
Sd (effective radiating area, sq. in.) 51.6616
Frequency range (Hz) 31-250
Energy Bandwidth Product (EBP) 74
Driver Physical Dimension
Speaker Displacement (cu ft.) 0.1268
Mounting hole diameter (mm) 238
Mounting hole diameter (inches) 9.37
Mounting depth (mm) 214
Mounting depth (inches) 8.425
Magnet Weight (Oz) 263.7
Basket diameter (inches)
Recommended Enclosures
Typical sealed enclosure (cu. ft.) 0.5 to 0.8
Vented enclosure (cu. ft.) 1.2
Port tuning frequency (Hz) 38
Port diameter (inside, in.) 3.4
Equivalent square port (in.) 3x3
Port length (in.) 12
Enclosure Details
1. Parameters listed are for conventional applications only, for further help please call Tech Audio Support
2. 1" MDF is recommended.
3. Recommended enclosures are NET Box Volumes, speaker and port displacement are calculated into the
volume of the enclosure, you will not need to add these volumes to calculate GROSS volume for the
enclosure.
*** Sub-sonic filters should always be used and adjusted specifically for vented box designs.
NOTE: The woofer must face up or down only, especially in sealed enclosures.
Specifications subject to change without notice
© 2007 Directed Electronics, Inc. Vista, CA 92081 All rights reserved.
24
Orions are made sort of weird unless its just me, i have a 15.4 hcca, i thought it was weird that according to the manual they suggest a sealed enclosure to be larger then the ported one. now every other sub ive seen its always been the other way around, ported enclosure requires more space. unless its a large typo the company never fixed, any idea why this particular sub is like that.
also here is the 2012 specs according to the orion manual, they are different the the ones the other guy posted and again it shows the sub requiring more space for a sealed than a ported enclosure
yeah its weird its like that sealed is larger
I have the same specs as kynto but thought it was weird and maybe the hcca would be like the L7 where they hit harder with more space. My friend and I built a box for his hcca 15 at about 4.9ft^3 and that thing hits pretty hard, just that 1 broke the trunk hatch of his pathfinder and the license plate ripped like a sheet of paper... I might experiment with this and see if I stuff the box if it will hit harder.I really appreciate your help guys I really didnt think anyone would reply with this funny sub situation
Crescendo bc3500
DD 9512i
  • Who's Online   0 Members, 0 Anonymous, 836 Guests (See full list)
